[Release] Nivo Slider V1.0.0
talonos
Portal Specialist
Portal Specialist
phpBB.com User: talonos
Post by talonos »
Addon: Nivo Slider
Addon Version: 1.0.0
Addon Author: Talonos
Addon Description:
This extension will add a Nivo Slider block to your portal page
REQUIRES Nivo Slider INSTALLED FROM HERE
IF UPGRADING "Nivo Slider" DISABLE "Nivo Slider Board3" extension BEFORE DOING SO or you can get locked out of ACP
Addon Requirements: Board3 Portal 2.1 and newer. Nivo Slider installed from HERE
Download Link:
http://pretereo-stormrage.co.uk/viewtopic.php?f=25&t=57
Instructions:
1. Unzip the downloaded release and copy it to ext/talonos (PHPBBROOT/ext/talonos/b3pnivoslider/composer.json)directory of your phpBB board. Navigate in the ACP to Customise -> Manage extensions . Look for Nivo Slider Board3 under the Disabled Extensions list, and click its Enable link
2. navigate to Extensions -> Portal -> Portal Modules and click "Add Module" for any side column and add B3P Nivo Slider.
3. all ACP settings are controlled via youtube gallery extension.
REVISION INFOMATION
1.0.0
Initial Release
SCREENSHOTS:
Return to “v2.1.x”
