Addon Version: 1.0.1
Addon Author: Talonos
Addon Description:
This extension will add a Youtube gallery recent video's block to your portal page
REQUIRES YOUTUBE GALLERY INSTALLED FROM HERE
IF UPGRADING "Youtube video gallery" DISABLE "Youtube Board3" extension BEFORE DOING SO or you can get locked out of ACP
Addon Requirements: Board3 Portal 2.1 and newer. Youtube gallery V1.0.2+ installed from HERE
Download Link:
http://pretereo-stormrage.co.uk/viewtopic.php?f=24&t=56
Instructions:
1. Unzip the downloaded release and copy it to ext/talonos (PHPBBROOT/ext/talonos/b3pyoutube/composer.json)directory of your phpBB board. Navigate in the ACP to Customise -> Manage extensions . Look for Youtube Board3 under the Disabled Extensions list, and click its Enable link
2. navigate to Extensions -> Portal -> Portal Modules and click "Add Module" for any side column and add Youtube Gallery.
3. all ACP settings are controlled via youtube gallery extension.
REVISION INFOMATION
1.0.1
updated to work with the release of phpbb 3.2 and youtube video gallery 1.0.3Code: Select all
Initial Release
