I only had to clear the board cache and it functioned in IE as it should.
Your Portal Version: 2.1.0
Boardlink: http://NS.FW
Nothing much. I use FF as my main browser and just now noticed that IE isn't loading the portal.
My board is NSFW so I won't be posting it.
My board in IE: http://i.imgur.com/wvby8uc.png
My board in FF: http://i.imgur.com/nmnyskt.png
The portal isn't working in IE for some reason. If I skip loading portal and goto a specific forum page like this: http://i.imgur.com/TYNqwQA.png then it loads but still doesn't show the portal sidebar which I have it set so that portal shows all pages.
I don't believe this is an issue specific to Board3 Portal but maybe you guys have an idea.
[SOLVED] Board3 Portal doesn't work/show in IE.
Re: Board3 Portal doesn't work/show in IE.
A functioning Boardlink would be helpful.Hexxus wrote: Boardlink: http://NS.FW
sgtevmckay
- phpBB.com User: sgtevmckay
Additionally: What version of PhPBB are you running?
The board is NSFW and of a taboo, if you continue to ask for it I will post it.archivar wrote:A functioning Boardlink would be helpful.Hexxus wrote: Boardlink: http://NS.FW
3.1.8sgtevmckay wrote:Additionally: What version of PhPBB are you running?
