portal 2.0.2 compatible with phpbb 3.0.14?
Current Version: 2.0.2
Released: 2013-10-27
Spakowski
Post by Spakowski »
Your Portal Version: 2.0.2
I was wondering if 2.0.2 is compatible with phpbb 3.0.14? I uploaded the portal using automod and it said it might break the forum.
Re: portal 2.0.2 compatible with phpbb 3.0.14?
It should be compatible with phpBB 3.0.14, make a backup and try it.
Have you tried it manually without Automod?
Spakowski
Post by Spakowski »
Just installed it on 3.0.14 & it works fine.
qoeple
phpBB.com User: qoeple
Post by qoeple »
Hi, can I install it with automod ?
Thanks
qoeple wrote:Hi, can I install it with automod ?
Thanks
I would not install with Automod.
Board3 Portal 2.0.2 should install with AutoMOD on phpBB 3.0.14 just fine.
