Addon Version: 1.0.1
Addon Author: Talonos
Addon Description:
This block will display on your portal and you can set certain goals for your board. posts/topics/users/files(attachments)/Views. each row can be configured in the ACP. set a goal and see if you can reach it! also animation for the bar overlay can be disabled inside the ACP per row. once a target is met "Goal Reached" will be displayed
Addon Requirements: Board3 Portal 2.1 and newer.
Download Link:
http://pretereo-stormrage.co.uk/viewtop ... t=52&p=146
Instructions:
1. Unzip the downloaded release and copy it to ext/talonos (PHPBBROOT/ext/talonos/b3pboardgoals/composer.json)directory of your phpBB board. Navigate in the ACP to Customise -> Manage extensions . Look for Board3 Board Goals under the Disabled Extensions list, and click its Enable link
2. navigate to Extensions -> Portal -> Portal Modules and click "Add Module" for the Center, Top OR Bottom Column and add Board Goals.
3. now configure your installed "Board Goals" module to your liking by clicking on the
REVISION INFOMATION
1.0.1
Fixed display conflict if using Stokers forumgoals extension.Code: Select all
Initial Release
