Portal not showing correctly on iPad
Taxuss
Post by Taxuss »
Your Portal Version: 2.1.0RC3
Boardlink: http://http://ligfietsforum.net/
MySQL Version: MySQL(i) 5.5.41-log
I did not know the problem was there in the first place. A member of the forum who surfed on an iPad
noticed me of the problem.
I tried searching the existing topics on this forum about this problem, but the links to said solutions were dead,
and I'm not even sure if those where solutions. I couldn't find any real solution.
And google translate is not the best.
Hi everybody.
First I want to thank you all for the work you put into this portal.
Now the problem is that I just got noticed from a member on my forum that the portal
does not work properly on an iPad. He said the blocks are overlapping each other.
I could not find any real solution to this problem, yet I've seen others have had the same problem.
My phpBB is 3.1.6.
On windows and PC this problem is non-existent, only on iPad. I'm not sure about Android, I haven't heard any problems yet from android users.
If there is anyone who knows how to solve this problem and if you can tell it to me, you have my eternal gratitude.
Regards,
Taxus
Re: Portal not showing correctly on iPad
Your portal version seems to be outdated. Please try again with the latest version: http://board3.de/viewtopic.php?f=40&t=11060
Taxuss
Post by Taxuss »
Marc wrote:Your portal version seems to be outdated. Please try again with the latest version: http://board3.de/viewtopic.php?f=40&t=11060
In my extension tab it says the version of the portal is 2.1.0. When I look at your topic it says the newest portal version is also 2.1.0. Are you sure it is outdated?
You had written that your Portal version is 2.1.0RC3
2.1.0RC3 is not the same as 2.1.0
This is based on your style files. I do not care what your ACP says in this case. Make sure to replace your extension's files with the ones from the latest released version.
