Your Portal Version: 2.1.0
PHP Version: PHP Version 5.6.10
Does anyone know under the USER MENU what the dimensions are for the avatar.
Cause, I'd like to make my phpbb board be set for 300x300 but I don't want avatars to be cut off when a user looks at the user menu on there computer screen
User Menu Avatar Dimensions
HoodieWeather
- phpBB.de User: Kirk
Re: User Menu Avatar Dimensions
The avatar of the USER MENU is set no any fixed size, there are the dimensions of which are set in the ACP / Avatar settings.
HoodieWeather
Hey last night I was farting around with it. I noticed if I had a 300x300 it didn't fit inside that small box, the best dimension is 150x150 and while browsing thru my forum and looking at my posts it looked good. I'm sure a higher dimension looks great browsing and looking at someones topic in forum, but as for the portal, having a higher dimen, shows up but it's cut off by the small user box, which you can edit the column, itself but its said not to and to keep it at 180
If your avatar 300px but the module has only 180px you need the column where the User Menu is larger.
HoodieWeather
so, I could have kept 300x300 but just expanded the column? If so okay thanks I didn't even think of doing thatKirk wrote:If your avatar 300px but the module has only 180px you need the column where the User Menu is larger.
But, it says its preff to be 180.. If i do one side, I'd have to do the other.
