Showing left and right columns on all pages, just not 1 side
HoodieWeather
Post by HoodieWeather »
If this is in the wrong place, please move. Thanks
Column to display on all pages:
Choose which column should be shown on all pages.
Please make another checkbox so we can have both on every page.
I"m sure that will be easy to do.. edit either one or two files, zip them up have us drag and drop into our FTP and we are good.
Re: Showing left and right columns on all pages, just not 1
You can only select either the left or right column, both do not go
HoodieWeather
Kirk wrote:You can only select either the left or right column, both do not go
CAN YOU PLEASE MAKE IT GO BOTH :-)
Don't want to go code hunting and try to figure it out :-(
sgtevmckay
phpBB.com User: sgtevmckay
Post by sgtevmckay »
I believe that I am also in favor here, not just both sides, but to choose left only Right Only or both.
Especially as I am moving to a screen wide Style, and most of my viewers are1920x1080, this should be an appropriate suggestion.
HoodieWeather
Hope, they will come out with a new version of portal or a patch, so we can have both sides showing at once. that would be really nice.
