Show server online/offline in left menu
Jumpman
Post by Jumpman »
Your Portal Version: 2.1.0
Boardlink: http://venskabsklanerne.dk/
PHP Version: PHP Version 5.4.45-0+deb7u2
Read in my questions
Yes read in my questions
I want to have my servers show online/offline on my portal front page http://venskabsklanerne.dk/ in the left menu at the bottom but it not like echo form my code
I try to include serverinfo.php in block with iframe it work but that i not like make a black box around my script
I use Extensions pages 1.0.3 i try to add my code to that to but it look like shit http://venskabsklanerne.dk/app.php/page ... 277f5be6c6 i think be cource i want to include header from phpbb3 but i don't know look like this when i not use pages http://venskabsklanerne.dk/serverinfo.php
Right now i just link to the server online/offline from a block like you see on my portal
link to server online/offline is http://venskabsklanerne.dk/infoserver.php (this is same script as serverinfo.php) and it work fine but phpbb3 style is not included in my script like above.
How do i include og add my code to the left menu in my portal so i can see if my server is online/offline ?
I need to have this 2 lines ind the script to
<meta http-equiv="refresh" content="10">
<link rel="stylesheet" type="text/css" href="../../../style.css">
serverinfo.php
define('IN_PHPBB', true);
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup();
page_header('Server Info');
   'body' => 'serverinfo_body.html',
make_jumpbox(append_sid("{$phpbb_root_path}viewforum.$phpEx"));
page_footer();
<h2>Server Info</h2>
<div class="panel">
   <div class="content">
<p align="center">
header('Content-Type: text/html; charset=UTF-8');
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>[VK] - Main Menu Right</title>
</head>
<body text="#BBBBBB" bgcolor="#000000" SCROLL="no" BOTTOMMARGIN="0" TOPMARGIN="0" RIGHTMARGIN="0" LEFTMARGIN="0" MARGINWIDTH="0" MARGINHEIGHT="0">
<table class="TRtable">
			<th>[VK] TEAMSPEAK SERVER</th></tr>
		<tr><td>
<!--[VK] TeamSpeak3 Server-->
<?PHP
$ts_ip = "151.80.90.218";
$ts_port = "10011";
$output = @fsockopen("$ts_ip", $ts_port, $errno, $errstr, 2);
socket_set_timeout($output, 000002);
if (!$output) {
    echo '<strong><font face="Comic Sans MS">[+35] TEAMSPEAK3 SERVER</font></strong><br />';
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">Server is:</strong> <span style="color:#F00;">Offline</font></span><br />';
} else {
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">[+35] TEAMSPEAK3 SERVER</font></strong><br />';
	echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">151.80.90.218:12270</font></strong><br />';
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">Server is:</strong> <span style="color:#0F0;">Online</font></span><br />';
    echo '<span style="color:grey;"><strong><font size=1 face="Verdana, helvetica, sans-serif"><a href="ts3server://151.80.90.218:12270/?channel=?password=">Join Here</a></font></strong></span><br />';
@fclose($output);
		</td></tr>
<br>
			<th>[VK] CSS SERVER</th></tr>
		<tr><td>
<!--[+35] CSS Fairplay For Adults I-->
<?PHP
$ts_ip1 = "5.135.161.166";
$ts_port1 = "27035";
$output1 = @fsockopen("$ts_ip1", $ts_port1, $errno, $errstr, 2);
socket_set_timeout($output1, 000002);
if (!$output1) {
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">[+35] CSS Fairplay For Adults I</font></strong><br />';
} else {
	echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">5.135.161.166:27035</font></strong><br />';
    echo '<span style="color:grey;"><strong><font size=1 face="Verdana, helvetica, sans-serif"><a href="steam://connect/5.135.161.166:27035">Join Here</a></font></strong></span><br />';
@fclose($output1);
		</td></tr>
		<tr><td>
<!--[+35] CSS FAIRPLAY FOR ADULTS [NO AWP/AUTO]-->
<?PHP
$ts_ip2 = "5.135.161.166";
$ts_port2 = "27036";
$output2 = @fsockopen("$ts_ip2", $ts_port2, $errno, $errstr, 2);
socket_set_timeout($output2, 000002);
if (!$output2) {
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">[+35] CSS Fairplay For Adults II<br />[NO AWP/AUTO]</font></strong><br />';
} else {
	echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">5.135.161.166:27036</font></strong><br />';
    echo '<span style="color:grey;"><strong><font size=1 face="Verdana, helvetica, sans-serif"><a href="steam://connect/5.135.161.166:27036">Join Here</a></font></strong></span><br />';
@fclose($output2);
		</td></tr>
		<tr><td>
<!--[WoF] CSS FAIRPLAY FOR ADULTS-->
<?PHP
$ts_ip3 = "5.135.161.166";
$ts_port3 = "27037";
$output3 = @fsockopen("$ts_ip3", $ts_port3, $errno, $errstr, 2);
socket_set_timeout($output3, 000002);
if (!$output3) {
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">[WoF] CSS FAIRPLAY FOR ADULTS</font></strong><br />';
} else {
	echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">5.135.161.166:27037</font></strong><br />';
    echo '<span style="color:grey;"><strong><font size=1 face="Verdana, helvetica, sans-serif"><a href="steam://connect/5.135.161.166:27037">Join Here</a></font></strong></span><br />';
@fclose($output3);
		</td></tr>
		<tr><td>
<!--[+35] CSS GUNGAME 5.1 SERVER-->
<?PHP
$ts_ip4 = "5.135.161.166";
$ts_port4 = "27038";
$output4 = @fsockopen("$ts_ip4", $ts_port4, $errno, $errstr, 2);
socket_set_timeout($output4, 000002);
if (!$output4) {
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">[+35] CSS GUNGAME 5.1 SERVER</font></strong><br />';
} else {
	echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">5.135.161.166:27038</font></strong><br />';
    echo '<span style="color:grey;"><strong><font size=1 face="Verdana, helvetica, sans-serif"><a href="steam://connect/5.135.161.166:27038">Join Here</a></font></strong></span><br />';
@fclose($output4);
		</td></tr>
		<tr><td>
<!--KRYPTONITE-DK-RETRO-GUNGAME-->
<?PHP
$ts_ip5 = "5.135.161.166";
$ts_port5 = "27039";
$output5 = @fsockopen("$ts_ip5", $ts_port5, $errno, $errstr, 2);
socket_set_timeout($output5, 000002);
if (!$output5) {
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">KRYPTONITE-DK-RETRO-GUNGAME</font></strong><br />';
} else {
	echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">5.135.161.166:27039</font></strong><br />';
    echo '<span style="color:grey;"><strong><font size=1 face="Verdana, helvetica, sans-serif"><a href="steam://connect/5.135.161.166:27039">Join Here</a></font></strong></span><br />';
@fclose($output5);
		</td></tr>
		<tr><td>
<!--[WoF] CSS GUNGAME 5.1 SERVER-->
<?PHP
$ts_ip6 = "5.135.161.166";
$ts_port6 = "27040";
$output6 = @fsockopen("$ts_ip6", $ts_port6, $errno, $errstr, 2);
socket_set_timeout($output6, 000002);
if (!$output6) {
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">[WoF] CSS GUNGAME 5.1 SERVER</font></strong><br />';
} else {
	echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">5.135.161.166:27040</font></strong><br />';
    echo '<span style="color:grey;"><strong><font size=1 face="Verdana, helvetica, sans-serif"><a href="steam://connect/5.135.161.166:27040">Join Here</a></font></strong></span><br />';
@fclose($output6);
		</td></tr>
<br>
			<th>[VK] CSGO SERVER</th></tr>
		<tr><td>
<!--[+35] CSGO FAIRPLAY FOR ADULTS-->
<?PHP
$ts_ip7 = "5.135.161.166";
$ts_port7 = "27041";
$output7 = @fsockopen("$ts_ip7", $ts_port7, $errno, $errstr, 2);
socket_set_timeout($output7, 000002);
if (!$output7) {
    echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">[+35] CSGO FAIRPLAY FOR ADULTS</font></strong><br />';
} else {
	echo '<strong><font size=1 face="Verdana, helvetica, sans-serif">5.135.161.166:27041</font></strong><br />';
    echo '<span style="color:grey;"><strong><font size=1 face="Verdana, helvetica, sans-serif"><a href="steam://connect/5.135.161.166:27041">Join Here</a></font></strong></span><br />';
@fclose($output7);
</font>
</body>
</html>
</p>
<!-- INCLUDE jumpbox.html -->
<!-- INCLUDE overall_footer.html -->
[/i]
Re: Show server online/offline in left menu
For this you have to create an own module. Create a module for Board3 Portal 2.1.x
