[DEV]mChat 0.3.4 with board3 portal capabilities
talonos
Portal Specialist
Portal Specialist
phpBB.com User: talonos
Post by talonos »
ok here we go with mChat 0.3.4 edited to work on board3 portal
original mChat source: https://www.phpbb.com/community/viewtop ... #p13846831
i had to do quite a few edits so please remember that the original source and also my edits are still [DEV]
download:
http://pretereo-stormrage.co.uk/viewtopic.php?f=20&t=49
installation:
upload extention to
ext/
after upload it should look like
ext/dmzx/mchat/composer.json
acp/customise/manage extension/ >> enable "mChat Extension"
acp/extensions/mChat/Configuration/ >> mChat On Portal: yes
acp/extensions/portal/portal modules/add module (top/center/bottom) >> Mini-Chat
and there you go mChat should be working on your portal and hopefully without issues :)
revision information
V3:
major update to ensure mchat will work on ALL pages that the portal is displayed on. app.php/portal being the main one.
german translation added for portal settings. thanks archivar
V2:
bug fixes:
display on index disabling whole portal block [FIXED]
display on portal config error [FIXED]
navigation menu missing [FIXED]
V1:
initial release
GameMASTER
Re: [DEV]mChat 0.3.4 with board3 portal capabilities
Post by GameMASTER »
sadly, not working for me... :(
portal-Box is empty, please keep up working on it!
talonos
Portal Specialist
Portal Specialist
Post by talonos »
check to see if this setting changes it.
acp/extensions/mchat/location on forum >> top of forum
GameMASTER
nothing changed, the whole chat is not working for me with your version :*(
website @ picload.org: https://pl.vc/4dzr7
acp @ picload.org: https://pl.vc/1gyw2
GameMASTER wrote:sadly, not working for me... :(
I can confirm that.
talonos
Portal Specialist
Portal Specialist
Post by talonos »
ok i'll look into it, i'll remove and reinstall on my tests and see where issue is comming from.
talonos
Portal Specialist
Portal Specialist
Post by talonos »
have you checked to see if mchat works on prosilver style at all. if it does work in prosilver then it should just be an easy fix. from the looks of it event for portal is loading but the style isn't.
ok i've worked out what the issue. the WoWDraenor itself is missing ALLOT of events in the style and where mchat uses events to hook into the style its cant do that if they don't exist hense why it is not showing up on your theme at all. i bet if you switched on prosilver theme it would work instantly as they has the events in place.
There appears no link to the chat as a separate page in the index.
talonos
Portal Specialist
Portal Specialist
Post by talonos »
read my edited post above.
I have tested with prosilver, but the same problems.
GameMASTER
of course i checked Prosilver-style as well, but it's the same... no working mchat.
talonos
Portal Specialist
Portal Specialist
Post by talonos »
hmmm ok just looked into it. i got it working on my test board here.
this is what i done.
acp/customise/style/ WoWDreanor >> inherits from "prosilver" ------- active >> "yes"
acp/general/board settings/ default style >> "WoWdreanor"
guest style >> "WoWdreanor"
override user style >> "yes"
as soon as i done that mchat popped up on both portal and index.
imgs http://imgur.com/a/55EtR
GameMASTER
hm... same settings @ my board, but no chat... i will try a fresh install @ another website and give it a try
maybe it fails because i had the original mchat installed before? i deaktivated it and deleted the files before i copied your files to my board...
talonos
Portal Specialist
Portal Specialist
Post by talonos »
is "mChat On Index:" = no ?
if "no" set to "yes" as just found a bug if that is set to "no"
GameMASTER
ok, now it's getting weird... on my cellphone (Galaxy S5) the chat apears and i can see, that some users already used it... now, i am really confused!
edit: on my fresh/clean install i have the same problem! (schattenraid.de)
edit 2: my fault - the chat appears in forumindex - but still nowhere @ portal
Return to “v2.1.x”
