I have been trying to get the older version that was created to work on the new releases of mChat, Board3 portal, phpbb 3.1.7 pl1 and have no luck getting it to work. I as well as several others would be most appreciative if someone with more coding knowledge then I would be kind enough to rewrite the older version that Marc had created.
Thanks!!
mChat on Board3 Portal 2.1.0 phpbb 3.1.7 pl1
- phpBB.de User: couchtiger
- phpBB.com User: couchtiger
Re: mChat on Board3 Portal 2.1.0 phpbb 3.1.7 pl1
I would also appreciate this! Thanks
- phpBB.de User: remkot
- phpBB.com User: remkot
Here to
For me the portal is not usfull whitout the mchat.
- Valued Contributor
- phpBB.de User: sina54
- phpBB.com User: sina54
ich arbeite mit iframe, besser wäre ein block, das wäre gut
i've got it working
i'm trying to get extention author to possibly implement my code so that board3 isn't left out
O good..i´m waiting!
cough cough HERE cough
