Home Tab
Jumpman
Home Tab
Post by Jumpman »
Your Portal Version: 2.1.0
Boardlink: http://5.135.161.166/
PHP Version: 5.4.45-0
MySQL Version: 5.5.46-0+deb7u1
Maybe be course of my black style but i dont know im not the best to do php yet
Yes but im not the best to make php yet :-(
I need help to add app.php to my home tab, every time i click i have to login again
First picture hven i click home here i stay login on my site
Second picture if i clice home tab here i need to login again be course aap.php not in the links, i have try to set it Board settings as http://5.135.161.166/app.php and http://5.135.161.166/app.php/portal but no luck now it stays just as http://5.135.161.166/
Im useing phpbb version 3.1.5
Can someone please help me to fix it
Re: Home Tab
Your board does not use cookies, but this is no problem from the portal.
Jumpman
Re: Home Tab
Post by Jumpman »
This have nothing to do with my board not use cookies, cookies active now still same problem
See my pictures when i click HOME TAB http://5.135.161.166/ i will logout when i click home link http://5.135.161.166/app.php/portal?sid ... 6473607e6b i will stay login this have something with the /app.php/ in the home links, this code are not in the HOME TAB so i will lose login.
Re: Home Tab
Your cookie settings are not correct, so please contact https://www.phpbb.com/
Re: Home Tab
You'll have to use {U_PORTAL} if you want to redirect to the portal and not hard code that link into your template file.
