UPDATED: 14 Feb 2016
Addon: Wildstar Guild Recruitment Module
Addon Version: 2.1.0
Addon Author: Talonos AND Aleyah
Addon Description:
This is a guild recruitment display module. Specs are displayed on the portal via images and transanercy for images is set in the ACP. also you can set a Priority level (none-low-medium-high), values will display in a nice mouseover tooltip that is customisable from a theme dropdown menu. you can set the block to only display classes that you are recruiting for OR display all classes. Class images can be enabled/disabled. Clicking on a spec image will direct you to the forum/link of your choosing for said clicker to make an application to the guild be it from an application form or a forum which is custonisable from the ACP aswell
Addon Requirements: Board3 Portal 2.1 and newer.
Download Link is here:
http://pretereo-stormrage.co.uk/viewtopic.php?f=18&t=43
Instructions:
1. Unzip the downloaded release and copy it to the ext directory of your phpBB board. Navigate in the ACP to Customise -> Manage extensions . Look for "Board3 Wildstar Recruitment Module" under the Disabled Extensions list, and click its Enable link
2. navigate to Extensions -> Portal -> Portal Modules and click "Add Module" for the Left OR Right Column and add "Wildstar Recruitment".
3. now configure your installed "Wildstar Recruitment" module to your liking by clicking on the
REVISION INFOMATION
v2.1.0
updated code to enable block loading images right when on app.php/portal
improved image linking to account for different .htaccess settings.
Updated to now use the new Extensions system for PHPBB 3.1+ and Board3 2.1+
Improved Tooltip Stability + modified to reduce conflict with other modules and added spec image within tooltip option
Initial Release by Aleyah
