Your Portal Version: 2.0.2
PHP Version: 3.0.13
How would one create a log in page like IE:
https://web.archive.org/web/20130401071 ... eaked.com/
But, they masked there phpbb as a website.
When you'd log in it would shoot you to I think
http://www.it-leaked.com/?/
If, you click forgot password it would shoot you to the forum part of the website
www.it-leaked.com/forum/ucp.php?mode=sendpassword
This is what the actual site looked like, when you post something it would spit the date to the back end of the website the forum part. The image sure looks like a portal to me, but It was a built from the ground up.
This, is where the info from users posts would go
https://web.archive.org/web/20130530203 ... /index.php
index.php is the forum end of the website
Site doesn't exist anymore.
Sorry for the rant, but I just want to know how to create a log in like that page i showed you, that would send users to the portal, instead of the index
Creating A Login Page That Shoots To Portal
HoodieWeather
- phpBB.de User: Kirk
Re: Creating A Login Page That Shoots To Portal
There is a login box to the portal.
To create another login page at phpbb.com ask.
