How can I have the links to portal AND phpbb
Current Version: 2.0.2
Released: 2013-10-27
Manu2
Post by Manu2 »
Your Portal Version: 2.0.2
Boardlink: http://www.flipper-fr.org/aquiflip/
Hi !
I would want to have both "Portal" and "Board Index" links at the top of my board, like here on this forum.
But I have only "Board Index" ("Index du forum" in french), so I can't go back to portal when I'm on the board.
I hope that my question is clear. :roll:
Thanks in advance for your answers.
Re: How can I have the links to portal AND phpbb
Open the install.xml by editing the overall_header.html and overall_footer.html as stated in this manual.
Manu2
Post by Manu2 »
Thanks a lot, Kirk, for your quick answer. Now it works !
My error, if it can use to others, was that I used "automod" to install board3, and I didn't see that the script modify the style prosilver. And it isn't the style I use on my site !
By modifying it manually, now, it's perfect. Thanks again !
