UPDATED: 28 Jan 2017
Addon: Warcraft Guild Recent Activity extension
Addon Version: 2.1.3
Addon Author: Talonos
Addon Description: This block is used to display recent activity within a set guild that will show stuff like achievements and epics aquired. very minimal setup required. just input region/realm/guild and set the amount of items you would like to display 1-25. theres also an option to disable images in the block so you can disable them if you have wowhead tooltips set to display icons.
Addon Requirements: Board3 Portal 2.1 and newer.
Download Link is here:
http://pretereo-stormrage.co.uk/viewtop ... t=42&p=106
Instructions:
1. Unzip the downloaded release and copy it to the ext directory of your phpBB board. Navigate in the ACP to Customise -> Manage extensions . Look for Board3 Warcraft Guild Recent Activity under the Disabled Extensions list, and click its Enable link
2. navigate to Extensions -> Portal -> Portal Modules and click "Add Module" for the Left OR Right Column and add Warcraft Guild Recent Activity.
3. now configure your installed Warcraft Guild Recent Activity module to your liking by clicking on the
4. ESSENTIAL - you need a battle.net api key from https://dev.battle.net to make this block functional. your key can be used accross multiple blocks so only 1 key is needed
REVISION INFOMATION
V2.1.3
Fixed quality output
Fixed Ilvl output
added collaspable category to extensionCode: Select all
attempted fix for Ilvl and qualityCode: Select all
added option to automaticly update display in the block every preset minutes
added ACP option "update time in minutes"
code version bumped to 2.1 instead of 2.0 due to missed error in code for update pushes.Code: Select all
Updated to now use the new Extensions system for PHPBB 3.1+ and Board3 2.1+Code: Select all
Battle.net api changes implemented. block now requires an apikey from https://dev.battle.net to function (key can be used for mulitple blocks)Code: Select all
Initial ReleaseACP
Portal Block
