Portal To Show Posts That Need To Be Modded.
Current Version: 2.0.2
Released: 2013-10-27
HoodieWeather
Post by HoodieWeather »
Your Portal Version: 2.0.2
PHP Version: PHP Version 5.6.10
Nothing.
Nothing
Under the 'User menu'
Is there a way to add a link that reads under, or above "Moderator Control Panel"
called "Posts To Be Moderated" With a number next to it, letting you know oh hey!! there's 24 posts that need to be accepted.
Thanks
Dave
