UPDATED: 17 Dec 2017
Addon: Warcraft Realm Status
Addon Version: 2.1.2
Addon Author: Talonos
Addon Description:
Block Which will display the current status of the warcraft realm selected.
Addon Requirements: Board3 Portal 2.1 and newer.
Download Link is:
http://pretereo-stormrage.co.uk/viewtopic.php?f=16&t=41
Instructions:
1. Unzip the downloaded release and copy it to the ext directory of your phpBB board. Navigate in the ACP to Customise -> Manage extensions . Look for Board3 Warcraft Realm Information Module under the Disabled Extensions list, and click its Enable link
2. navigate to Extensions -> Portal -> Portal Modules and click "Add Module" for the Left OR Right Column and add Realm Infomation.
3. now configure your installed Realm Infomation module to your liking by clicking on the
This Extension requires a Battle.net API key that can be aquired by registering @ https://dev.battle.net
Demo: http://pretereo-stormrage.co.uk/
REVISION INFOMATION
V2.1.2
Removed "Tol-Barad" & "Wintergrasp" from code as this info is not released from battle.net anymore and if it was selected to display them 2 items it would break javascript on portal
added option to automaticly update display in the block every preset minutes
added ACP option "update time in minutes"
updated code to enable block loading images right when on app.php/portal
Updated to now use the new Extensions system for PHPBB 3.1+ and Board3 2.1+
changed the realm display image to use local images on your server instead of remote as the remote system was unstable. redesigned the image aswell and given the option to select either Horde OR Allaince background image for the realm status
Initial Release
