UPDATED: 06 dec 2015
Addon: guildox.com Guild Rankings
Addon Version: 2.0.0
Addon Author: Talonos
Addon Description: this block can display 3 images from guildox.com using your predefined settings. them 3 images have different information about your guilds progress within world of warcraft.
- Raid progress
- Raid achievements
- Battleground ranking
your guild a PVP guild but you want to display your battleground info ONLY? well thats possible as you can set it in the ACP to only display the images you require.
EXAMPLE:
25man raiding guild setup;
raid ranking = on
raid achievmenets = on
battleground rankings = off
having it that way will minimise the display abit and show just the info they want to show.
Addon Requirements: Board3 Portal 2.1 and newer.
Download Link is here:
http://pretereo-stormrage.co.uk/viewtopic.php?f=15&t=40
Instructions:
1. Unzip the downloaded release and copy it to the ext directory of your phpBB board. Navigate in the ACP to Customise -> Manage extensions . Look for Board3 Guildox Module under the Disabled Extensions list, and click its Enable link
2. navigate to Extensions -> Portal -> Portal Modules and click "Add Module" for the Left OR Right Column and add "Guildox.com rankings".
3. now configure your installed "Guildox.com rankings" module to your liking by clicking on the
REVISION INFOMATION
2.0.0
Updated to now use the new Extensions system for PHPBB 3.1+ and Board3 2.1+Code: Select all
Updated: now works with guildox's redesgined website. there is only 3 images available now as ranking are not ranked by group size anymore.Code: Select all
Updated to include FLEX raid progressCode: Select all
Initial Release
