Your Portal Version: 2.1.0b1
Boardlink: http://www.gopherpucklive.com/forum/portal
Nothing
No
I am wondering if I can get the CENTER POLL results to be longer? They have always been short compared to the main forum poll.
You can see what I mean here:
Portal Poll: http://www.gopherpucklive.com/forum/portal
Forum Poll: http://www.gopherpucklive.com/forum/vie ... 13&t=12715
You can see in the Forum that they results are more "pronounced". How can I get that in the portal poll?
Poll result length?
- Portal Specialist
- phpBB.com User: talonos
Re: Poll result length?
if your running the newest version of board3 portal then you can set the poll as a "Top" or "Bottom" block which would make it full width of portal. full width on "center" is not possible.
No... That's not what I mean. I mean the actual length of the poll results. The bars are so short on portal compared to the forum.
- Portal Specialist
ahh ok so i've just looked at the coding quickly and i can see the difference.
Forum html shows
and the portal html shows
so from the looks of that it could be a coding error inside of your portal theme OR CSS error. that might give you an idea where to look. i'd have a look if i had more time but currently streched.
Forum html shows
<dd class="resultbar hidden" style="display: block;"><div style="width:100%;" class="pollbar1">31</div></dd>
<div class="pollbar1" style="width:100%;">31</div>
</dd>
<dd class="resultbar"><div style="width:17%;" class="pollbar1">31</div></dd>
You put me on the right track. It was in the poll.php module file.
I found this: $option_pct_txt = sprintf("%.1d%%", round($option_pct * 100));
and change it to this: $option_pct_txt = sprintf("%.1d%%", round($option_pct * 500));
Now the poll results fill the space much better.
- Portal Specialist
ok so looks like you might have found a coding error, good to see you got it working correctly now
I don't even know if that IS the error. In the forum is is coded at * 100 too.... But I needed to alter it to * 500 to get it to work on the portal poll. Strange.
- Portal Specialist
ok so its a temp fix. i'll look over it when i have more time.
Spoke too soon.... It fixed the bar length, but messed up the % amount. So back to the drawing board.
- phpBB.de User: Kirk
The Poll lenght is in the root/ext/board3/portal/modules/poll.php defined:
100 = 100%
