Getting Portal to frontpage
SotD
phpBB.de User: SotD
phpBB.com User: SotD
Post by SotD »
This is probably a very basic question - But I am less than basic :)
I would like to have the Portal as my front page. At the moment only the left part is visable. What to do?
Re: Getting Portal to frontpage
Open: root/.htaccess
Add the following to the end
SotD
phpBB.de User: SotD
Post by SotD »
Doesn't seem to do the trick unfortunately...
You can probably not tell anything from my site link, but if you in some magical way can, then this is it:
http://www.fmdanmark.dk
You have to edit the .htaccess is the root in your forums (there where the config.php is)
SotD
phpBB.de User: SotD
Post by SotD »
Kirk wrote:You have to edit the .htaccess is the root in your forums (there where the config.php is)
Great. Thanks a lot!
How do I change "Portal" to another name eg. "Home" ? I mean in the top, just below the banner.
SotD wrote:How do I change "Portal" to another name eg. "Home" ? I mean in the top, just below the banner.
Open: root/board3/portal/language/en/portal.php
Find:
	'PORTAL'			=> 'Portal',
Replace with:
	'PORTAL'			=> 'Home',
Encoding the File with UTF-8 without BOM.
SotD
phpBB.de User: SotD
Post by SotD »
Seems to work, but for some reason it just seems to be called "Portal" everywhere...
When I open the site it is called
http://fmdanmark.dk/app.php/portal
I would prefer it to be called http://fmdanmark.dk when I click the banner, and when people make it a favorite.
So far, thanks a LOT for the help. I would have never managed to get this far without help. I hope you can keep helping me to tweak it ever so slightly :)
There is a possibility but this is not recommended.
Open: root/ext/board3/portal/styles/prosilver/template/event/overall_footer_breadcrumb_prepend.html and root/ext/board3/portal/styles/prosilver/template/event/overall_header_breadcrumb_prepend
Find:
{U_PORTAL}
Replace with:
http://fmdanmark.dk
You can view the portal without app.php
Go to ACP/Server settings by Enable URL Rewriting: set it to yes.
sina54
phpBB.de User: sina54
phpBB.com User: sina54
Post by sina54 »
das klappt nicht..Ich kann dann nicht mehr auf das Portal zugreifen
ich denke ich muss meine Internetadresse reinsetzen..o je..ich bin doof..lol
lg sina
Jetzt geht mein "Portal" nicht da ist keine Route hin
nur bei Startseite geht alles..auch der chat..Wie kann ich jetzt das Portal wieder aktivieren wie es bei der -startseite geht?
Ich verstehe nicht ganz dein Problem, deine Starseite ist doch das Portal.
sina54
mchat und Portal sowie doppelte Einträge
Post by sina54 »
bei mir stand Startseite-Portal-und forumsübersicht (ich habe heute einfach das Portal rauskopiert damit niemand mehr draufgeht da es nicht auf das Portal führt sondern auf einen fehlenden Pfad führt)
Die startseite soll Portal heissen nicht Startseite das wäre gut!
Ich hab noch ein Problem der Chat macht doppelt und dreifache Einträge was mache ich da falsch? (scheint aber nur bei mir zu sein..Die User beklagen sich nicht)
lg Sina
http://www.duwirstvermisst.de
sina54 wrote:Die startseite soll Portal heissen nicht Startseite das wäre gut!
Dann trage doch im ACP bei Homepage-URL Text Portal ein.
sina54
Post by sina54 »
JEtzt jklappts mal allerdings nicht wenn ich den Styl wechsele
ich habe SE Square für Gäste eingestellt..soweit alles klar
wenn ich mich anmelde kommt mein styl aero
dann sehe ich keinen chat mehr
diesen link sehe ich dann
http://www.duwirstvermisst.de/portal?si ... da2d688177
leider kein chat
erst wenn ich wieder auf Startseite gehe bzw. Portal
