Your Portal Version: 2.1.0
Boardlink: http://www.ferrosim.es
Hello.
Is there any possibility of integrating the "Recent topics" extension in a center module of the portal?
Thank you.
Recent topics extension integration?
- phpBB.com User: Bermudez
Re: Recent topics extension integration? (Solved)
Solved very easily making visible all subforums in the news module, and changing the title of the module.
Why did not I think of that before?
Regards.
Regards.
Can you please tell me exactly what you have done?
Edit: Or anyone who understand this.
Edit 2: finished it
Edit 2: finished it
