LATEST_NEWS - Too mach space for column 'LAST_POST'
demonlibra
phpBB.com User: demonlibra
Post by demonlibra »
Your Portal Version: 2.1.0
Boardlink: http://forum.tecnocom-ug.ru
PHP Version: 5.3.13
MySQL Version: 5.1.41
I try to edit file "...\ext\board3\portal\styles\prosilver\theme\portal.css".
But after my changes, if I change width window of browser style is broken.
In module "LATEST_NEWS" too mach space for column "LAST_POST"
demonlibra
Re: LATEST_NEWS - Too mach space for column 'LAST_POST'
Example with option "Display the number of replies and views" = "No"
Open: root/ext/board3/portal/styles/stylename/theme/portal.css
Find and delete this:
ul.topiclist dt .list-inner {
   margin-right: 60%;
ul.topiclist dt {
   margin-right: -60%;
ul.responsive-portal-news dd:last-of-type, ul.responsive-portal-announcements dd:last-of-type,
#portal-forumlist ul dd:last-of-type {
   width: 25%;
dd.responsive-portal-news:last-of-type, dd.responsive-portal-announcements:last-of-type {
   width: 25%;
.rtl ul.topiclist dt .list-inner {
   margin-left: 60%;
.rtl ul.topiclist dt {
   margin-left: -60%;
.rtl ul.responsive-portal-news dd:last-of-type, ul.responsive-portal-announcements dd:last-of-type,
.rtl #portal-forumlist ul dd:last-of-type {
   width: 25%;
.rtl dd.responsive-portal-news:last-of-type, dd.responsive-portal-announcements:last-of-type {
   width: 25%;
Check if it is in the responsive view display errors.
demonlibra
Thank you.
Not perfect, but without these rows much better.
kárbiko
phpBB.com User: karbiko
Post by kárbiko »
Hi!
I've tried this modification, but can not see any difference in those two columns length.
They are in the same positions..
How can be expanded width of the first one in left ?
Thanks in advance
demonlibra
Did you Purge the cache?
demonlibra
On width between 895...1040px was some problem
I done some modification
1. .../ext/board3/portal/styles/prosilver/theme/portal_responsive.css
  • 1.1 Add to the top
ul.topiclist dt { margin-right: -340px; }
ul.topiclist dt .list-inner { margin-right: 40%; }
.forabg li.header dd { display: block; }
.forabg li.header dt, .forabg li.header dt .list-inner { float: left; width: 100% }100% }
  • 1.2 After this code
@media only screen and (max-width: 1040px), only screen and (max-device-width: 1040px)
  • add
.responsive-portal-news dd.lastpost { width: 150px; }
dd.lastpost.responsive-portal-news { width: 150px; }
  • 1.3 Replace
.responsive-portal-news dt { width: 130% !important; }
  • to
.responsive-portal-news dt { width: 100% !important; }
2. For style .../styles/basic_red/theme/stylesheet.css and .../styles/elegance_steelblue/theme/stylesheet.css
  • Search
.forabg li.header dt,.forabg li.header dt .list-inner{
  • and delete
margin:0;
Bermudez
phpBB.com User: Bermudez
Post by Bermudez »
Sorry for reviving this topic after so long.
It's just to remind the developer that keep in mind this change in the next portal release because this way this module looks much better aesthetically.
Regards.
Neverlands
Post by Neverlands »
here are the changes I've made for myself.
/ext/board3/portal/styles/{YOUR-STYLE}/theme/portal.css
Add:
/* Latest Posts */
ul.topiclist.topics.responsive-portal-news dt .list-inner .pagination, ul.topiclist.topics.responsive-portal-announcements dt .list-inner .pagination {
	margin-top: -3px !important;
@media only screen and (min-width: 1190px) {
	ul.topiclist.topics.responsive-portal-news dd.posts, ul.topiclist.topics.responsive-portal-news dd.topics, ul.topiclist.topics.responsive-portal-news dd.views,
	ul.topiclist.topics.responsive-portal-announcements dd.posts, ul.topiclist.topics.responsive-portal-announcements dd.topics, ul.topiclist.topics.responsive-portal-announcements dd.views {
		width: 65px !important;
	ul.topiclist.topics.responsive-portal-news dt .list-inner, ul.topiclist.topics.responsive-portal-announcements dt .list-inner {
		margin-right: 41% !important;
	dd.posts.responsive-portal-news, dd.posts.responsive-portal-announcements {
		margin-left: 18.5% !important;
	dd.views.responsive-portal-news, dd.views.responsive-portal-announcements {
		margin-left: -31px !important;
	dd.lastpost.responsive-portal-news, dd.lastpost.responsive-portal-announcements {
		margin-left: -20px !important;
	ul.topiclist.topics.responsive-portal-news dd.posts, ul.topiclist.topics.responsive-portal-announcements dd.posts {
		margin-left: 20% !important;
	dd.responsive-portal-news:last-of-type, dd.responsive-portal-announcements:last-of-type,
	ul.responsive-portal-news dd:last-of-type, ul.responsive-portal-announcements dd:last-of-type, #portal-forumlist ul dd:last-of-type {
		width: 20% !important;
