Custom Box Indentions / Color fixes
Ostdarva
phpBB.com User: Darva
Post by Ostdarva »
Your Portal Version: 2.1.0-RC2
Boardlink: http://evocaticlan.com/forum/portal
PHP Version: Most recent
MySQL Version: Most recent
I created a new "custom field" box.
Using different sizes on the width/height of the script
Alright, so there are a couple issues going on here with the portal. Would REALLY appreciate some help here. Thanks guys!
1. The colors are off (as shown in the picture), which file is in control of mandating the background colors of the boxes?
2. On "custom" boxes there are spaces within the box which is causing a fitting issue.
There is also a fitting issue in the main section for announcements/news and the header image.
3. Is there any way to get the top bar from my forum sections to appear on the top of each box in order to match my theme?
Thank you guys for everything you do.
Ostdarva
Re: Custom Box Indentions / Color fixes
1. You have in the colours.css change:
ul.forums {
    background-color: #eef5f9;
    background-image: url("./images/gradient.gif");
2. How is the Code of TeamSpeak?
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
check you CSS file. seems theres an issue with
postbody portal-module-postbody
inside of there.
Ostdarva
Post by Ostdarva »
Thank you!
Kirk wrote:1. You have in the colours.css change:
ul.forums {
Here is my teamspeak code (Teamspeak is not the only box with the spacing issue.. ;
the spacing issue is in all custom boxes and even in the announcements part too
<iframe src="http://cache.www.gametracker.com/components/html0/?host=63.209.37.190:9170&bgColor=333333&fontColor=CCCCCC&titleBgColor=222222&titleColor=FF9900&borderColor=555555&linkColor=FFCC00&borderLinkColor=222222&showMap=0&currentPlayersHeight=600&showCurrPlayers=1&showTopPlayers=0&showBlogs=0&width=180" frameborder="0" scrolling="no" width="180" height="788"></iframe>
Ostdarva
Post by Ostdarva »
I believe I replied to this already. Is staff on this board slow?
We support in our free time, have a little patience.
Increase the column width of the left modules.
Ostdarva
Post by Ostdarva »
Kirk wrote:We support in our free time, have a little patience.
I fixed the issue myself, the portal conflicts with the extension "left profile view".
Now for another question, is there any way to get the portal to show the full post of announcements (including bbcodes/images, ect) going downwards. Instead of having one announcement displaying in the box and creating alternate pages for the others.
Also, is there a way to get a PhpBB Gallery to display in a box?
