How Do I Get Forum in portal
pokyto
Translator
phpBB.com User: pokyto
Post by pokyto »
Your Portal Version: 2.1.0-RC2
Hi all!
How to get my forum (and phpbbgalery) in my portal?
like that => https://www.m-a-styles.de/viewforum.php?f=2
May be i'm blind but after search i didn't find a solution here
Thx!
Re: How Do I Get Forum in portal
Unfortunately, there is no gallery module for the portal 2.1.x.
Unfortunately, my knowledge is not enough to program a gallery module.
pokyto
Translator
Post by pokyto »
ok thx
forget the galery ... what is the solution to include the forum in the portal like the exemple i gave : https://www.m-a-styles.de/viewforum.php?f=2 ??
regards
pokyto
Translator
Post by pokyto »
i will try that
thx!
