Is there a database uninstall script for the portal?
pokyto
Translator
phpBB.com User: pokyto
Post by pokyto »
Your Portal Version: 2.0.2
PHP Version: 5.4.12
Hi all
before upgrading from 3.0.x to 3.1.x i just want to uninstall all the DB entries made by the portal install
i'll reinstall a fresh version of the portal just after the upgrading in 3.1.x
Is there a script or a sql command to do so ?
Thx
Re: Is there a database uninstall script for the portal?
You should upload the installer of Board3 Portal 2.0.2 and use its uninstall feature. ;)
pokyto
Translator
Post by pokyto »
so easy !!!
thx a lot
