Is Portal 2.0.0b1 compatible with PHP 5.6?
Current Version: 2.0.2
Released: 2013-10-27
Leinad4Mind
phpBB.de User: Leinad4Mind
phpBB.com User: Leinad4Mind
Post by Leinad4Mind »
Your Portal Version: 2.0.0b1
PHP Version: 5.6
Nothing
Nothing
Hi there, I've been using the Portal since 2012, and my host provider in September will change the PHP to 5.4.
I've test out the 5.4 and it works perfectly. But, the host have and recommend to use 5.6 (last version), but when using 5.6 the Portal mess all around.
The blocks stretch all along horizontally.
Can anyone test this on a fresh install, please?
Re: Is Portal 2.0.0b1 compatible with PHP 5.6?
This is a beta version, i.e. the package may still contain errors.
I tested with:
PHP Version 5.6.10
phpBB Version 3.0.13-PL1
Board3 Portal Version 2.0.2
I could not see any problems.
After the conversion of PHP version may be necessary in some cases, adjusting your scripts.
