Images Not Showing Correctly
Xx_iDon_xX
phpBB.com User: Xx_iDon_xX
Post by Xx_iDon_xX »
Your Portal Version: 2.1.0-RC2
Boardlink: http://clan-tac.com
Nothing
Nothing
http://prntscr.com/73w0am
images not showing. ive put a red arrow to where they dont show. anyway this can be fixed?
Re: Images Not Showing Correctly
copy: root/ext/board3/portal/styles/prosilver/theme/images/portal/*.*
to: root/ext/board3/portal/styles/digi/theme/images/portal/*.*
random_rodder
phpBB.com User: random_rodder
Post by random_rodder »
I am having the same issue with two themes on my forum as well. Copying the files to the ext/... folders did not solve the problem.
Additionally, the images do not show up in the ACP/Portal Modules screen:
Also, I get this message when I update the B3P settings in the ACP:
Copying the portal/images folder to the forum/styles/themes/etc... folders solved the problem with the second image shown above, however, even after clearing the board cache, the images still do not show up in the two new themes I've added.
Create in root / ext / board3 / portal / styles / digi an empty directory named template.
So it should work.
random_rodder
Here are my directories as they show on my server:
tandycoco/forum/ext/board3/portal/styles/Elegance/theme/images/portal
tandycoco/forum/ext/board3/portal/styles/AllenStyle-SUBSILVER/theme/images/portal
The images have been copied to each directory. Are you saying the images should be in a folder named template and not theme like the Prosilver theme has them as shown below?
tandycoco/forum/ext/board3/portal/styles/prosilver/theme/images/portal
Create a separate directory for each style.
random_rodder
Kirk,
I do have each style in it's own directory:
The image above shows the path I had to place the portal images in to remove the ACP message I was getting
The image below is the path as I understood it for each style being placed in the Board3 Portal directory in /ext...
The directories for both styles are in the same format as shown above. Neither of which is solving my issue. You can see the portal at: www.tandycoco.com/forum
You have the graphics in ./forum/styles/AllanStyle-SUBSILVER/theme/images/portal
It should, however, so be ./forum/ext/board3/portal/styles/AllenStyle-SUBSILVER/theme/images/portal
Your Code:
changed Code:
random_rodder
This is still an issue for me.
There are three styles installed on my forum, and I have the portal images files stored to two places for each theme.
Place one - webpage/forum/ext/board3/portal/styles/*themename*/theme/images/portal
Should that not be the appropriate folder on each theme for the icon images?
The second place they are stored is due to an error I got on the ACP, shown below:
If I copy the images to: webpage/forum/styles/*themename*/theme/images/portal folder, that warning goes away. However, even in the ACP when looking at the portal modules settings, I do not see the icons that should be there.
So in summary, the Prosilver theme works as expected, except the portal module icons do not show up in the ACP panel. The other two style I have installed, are lacking the module icons in the ACP and on the portal page as well.
For your style AllanStyle-SUBSILVER you took the portal files from prosilver, you must use the files from subsilver2 Copy the directories theme and template to root/ext/board3/portal/styles/AllanStyle-SUBSILVER/
For Style elegance copy the directories theme and template from ext/board3/portal/styles/prosilver to root/ext/board3/portal/styles/elegance/
