National Flags on Board 2.1.0 RC2
bennybernaer
phpBB.de User: /
phpBB.com User: bennybernaer
Post by bennybernaer »
Your Portal Version: 2.1.0 RC2
Your phpBB Type: other phpBB Distribution
How to get the national flags extension instead of on the forum index on the portal?
Who can give me this explain step by step?
Thanks!
www.proanamia.nl
bennybernaer
phpBB.de User: /
Re: National Flags on Board 2.1.0 RC2
I would like the flags block down to move to the portal. I added the following changes, but unfortunately does not work. What am I doing wrong and how to get it working properly?
ext\board3\portal\styles\prosilver\template\portal\modules
[c]flags_center.htm[/c]
<div class="panel bg1 portal-no-margin" id="flags">
   <ul class="topiclist bg1">
      <li class="header">
         <dl>
            <dt><div class="list-inner"><!-- IF U_FLAGS --><a href="{U_FLAGS}"><!-- ENDIF -->{L_NATIONAL_FLAGS}<!-- IF U_FLAGS --></a><!-- ENDIF --></div></dt>
         </dl>
      </li>
   <ul class="flags">
   <!-- BEGIN flag -->
      <li class="bg1">
         <a href="{flag.U_FLAG}">{flag.FLAG}</a><br />{flag.L_FLAG_USERS}
      </li>
   <!-- END flag -->
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
[c]flags.php[/c]
* @package Board3 Portal v2 - National flags
namespace board3\portal\modules;
* @package National flags
class portal_flags extends module_base
   * top      1
   * left      2
   * center   4
   * right      8
   * bottom   16
   public $columns = 21;
   * Default modulename
   public $name = 'PORTAL_FLAGS';
   * Default module-image:
   public $image_src = 'portal_custom.png';
   * module-language file
   public $language = 'portal_flags_module';
   * custom acp template
   * public $custom_acp_tpl = 'acp_portal_';
   /** @var \phpbb\config\config */
   protected $config;
   /** @var \phpbb\template */
   protected $template;
   /** @var string PHP file extension */
   protected $php_ext;
   /** @var string phpBB root path */
   protected $phpbb_root_path;
   * Construct object
   * @param \phpbb\config\config $config phpBB config
   * @param \phpbb\request\request $request phpBB request
   * @param \phpbb\template $template phpBB template
   * @param \phpbb\user $user phpBB user
   * @param string $phpbb_root_path phpBB root path
   * @param string $phpEx php file extension
   public function __construct($config, $phpEx, $phpbb_root_path)
      $this->config = $config;
      $this->template = $template;
      $this->phpbb_root_path = $phpbb_root_path;
      $this->php_ext = $phpEx;
   * {@inheritdoc}
//Begin: National_Flag
if (!empty($config['allow_flags']))
   if (!function_exists('top_flags'))
      include($phpbb_root_path . 'ext/rmcgirr83/nationalflags/functions_nationalflags.php.' . $phpEx);
   top_flags();
//End: National_Flag
return 'flags_center.html';
      return array(
         'title'   => 'PORTAL_FLAGS',
         'vars'   => array(
         'legend1'                            => 'ACP_FLAG_SETTINGS',
   * {@inheritdoc}
        return true;
   * {@inheritdoc}
       return true;
[c]portal_flags_module.php[/c]
* [Dutch] translated by Dutch Translators (https://github.com/dutch-translators)
* @package Board3 Portal v2.1 - national flags
* @copyright (c) 2013 Board3 Group ( www.board3.de )
* @license http://opensource.org/licenses/gpl-2.0.php GNU General Public License v2
* DO NOT CHANGE
if (!defined('IN_PHPBB'))
   exit;
   $lang = array();
// DEVELOPERS PLEASE NOTE
   'PORTAL_FLAGS'  => 'National flags',
Theriddler
Post by Theriddler »
Hi Benny
I've just finished a module for national flags for board 3 portal.
You can download it here: https://www.phpbbservice.nl/forum/viewt ... 168#p76168
