Paypal donate module
Barryoneoff
phpBB.de User: Theelf
phpBB.com User: Theelf
Post by Barryoneoff »
Your Portal Version: 2.1.RC2
Boardlink: http://www.eastlondonforum.co.uk
PHP Version: 3.1.3
Nothing
Nothing
Is there any way to change the default from Euro to GBP and is there any way to change the words on the module?
Re: Paypal donate module
Barryoneoff wrote: Is there any way to change the default from Euro to GBP and is there any way to change the words on the module?
Can you choose the module on the portal page.
Change text in ---->root/ext/board3/portal/language/en/modules/portal_donation_module.php
Barryoneoff
Thanks, I will try that.
Barryoneoff
Thanks. That worked for the text but I could not find the way to change Euro to GBP as default.
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
you'd have to edit the template file for that.
EDIT:
ext/board3/portal/styles/YOUR_THEME/template/portal/modules/donation_side.html
FIND:
		<select name="currency_code" class="autowidth">
        	<option value="USD">USD</option>
			<option value="AUD">AUD</option>
			<option value="CAD">CAD</option>
			<option value="CZK">CZK</option>
			<option value="DKK">DKK</option>
			<option value="EUR" selected="selected">EUR</option>
			<option value="HKD">HKD</option>
			<option value="HUF">HUF</option>
			<option value="NZD">NZD</option>
			<option value="NOK">NOK</option>
			<option value="PLN">PLN</option>
			<option value="GBP">GBP</option>
			<option value="SGD">SGD</option>
			<option value="SEK">SEK</option>
			<option value="CHF">CHF</option>
			<option value="JPY">JPY</option>
REPLACE WITH:
			<option value="EUR">EUR</option>
			<option value="GBP" selected="selected">GBP</option>
after doing them edits purge your cache and refresh your theme.
Barryoneoff
Thank you. :)
Barryoneoff
I am using Prosilver SE, which does not appear in the templates. I have changed the code in Prosilver and Subsilver2 but the default remains as EUR.
You must also change it in "prosilver SE".viewtopic.php?f=71&t=10968#p35799
Barryoneoff
Prosilver SE doesn't appear in the portal/styles folder.
Barryoneoff wrote:Prosilver SE doesn't appear in the portal/styles folder.
You have to open a new thread at this link: viewforum.php?f=73
