Your Portal Version: 2.1.x RC
Boardlink: http://www.eastlondonforum.co.uk
PHP Version: 3.1.3
Installed new style
Nothing. Reverted back to old style.
I just installed the prosilver special edition style and everything looks great, until I go to the portal page. The centre column is printing vertically instead of horizontal! I have had to revert back to the normal style until I find a solution.
Portal corrupted after style change
Barryoneoff
- phpBB.de User: Theelf
- phpBB.com User: Theelf
- phpBB.de User: Kirk
Re: Portal corrupted after style change
The style is too small, open root/styles/prosilver_se/theme/stylesheet.css
Find:
Replace with:
additional changes:
purge your browser cache
Find:
max-width: 850px;Code: Select all
max-width: 1152px;purge your browser cache
Barryoneoff
Absolutely brilliant! Thank you.
