Your Portal Version: 210_rc1
Boardlink: http://hd-forum.no
Upgraded forum from 3.012 to 3.1.2
Upgraded Portal to 210_rc1
Downgraded moderator to ordinary user, and the upgraded the user to meoderator again in case it was just the db that didn't stored it right.
Searched this forum
The Team block is just showing Administrators, and not Moderators in portalpage. Elsewhere in the forum they shows as they should.
I have Set the "Extended Leaders / Team:" to yes, just to hide moderatortitle for now.
I would like it to show Moderators as well, so I need a solution to fix this minor issue.
Thanx
[Solved] The Teamblock on portal
Topic author - Translator
- phpBB.com User: Terje Styve
Re: The Teamblock on portal
Hi there. This pull request should fix the mentioned issue with the team block:
https://github.com/board3/Board3-Portal/pull/453
It will be included in the next release of the portal.
Excelent! I thought I had done something wrong during installation. Looking forward to the upgrade. This is an excelent portal by the way.
Thanx!
Thanx!
