own custom block with javascript
Harledir
Post by Harledir »
Your Portal Version: 2.1.0-RC1
Boardlink: http://legion-of-lost-souls.eu
hi all,
i am trying to get 2 custom blocks to work within the portal. Both of these have a javascript for the actual content. The javascript pulls the information off a remote site (to show server status and teamspeak3 server).
Both blocks are showing up fine on the portal. The javascript is not being excuted or shown. If i add a <p>Hello World!</p> to the content it is being shown fine.
Server status block:
{$LR_BLOCK_H_L}LotRO Server Status{$LR_BLOCK_H_R}
<p>Hello World!</p>
<script type="text/javascript" src="http://lux-hdro.de/serverstatus-widget.php?snowbourn=1"></script>
teamspeak server block
{$LR_BLOCK_H_L}Teamspeak3 Server{$LR_BLOCK_H_R}
<p>Hello World!</p>
<div id="ts3viewer_1057264" style="width:; background-color:;"> </div>
<script type="text/javascript" src="http://static.tsviewer.com/short_expire/js/ts3viewer_loader.js"></script>
var ts3v_url_1 = "http://www.tsviewer.com/ts3viewer.php?ID=1057264&text=000000&text_size=12&text_family=1&js=1&text_s_weight=bold&text_s_style=normal&text_s_variant=normal&text_s_decoration=none&text_s_color_h=525284&text_s_weight_h=bold&text_s_style_h=normal&text_s_variant_h=normal&text_s_decoration_h=underline&text_i_weight=normal&text_i_style=normal&text_i_variant=normal&text_i_decoration=none&text_i_color_h=525284&text_i_weight_h=normal&text_i_style_h=normal&text_i_variant_h=normal&text_i_decoration_h=underline&text_c_weight=normal&text_c_style=normal&text_c_variant=normal&text_c_decoration=none&text_c_color_h=525284&text_c_weight_h=normal&text_c_style_h=normal&text_c_variant_h=normal&text_c_decoration_h=underline&text_u_weight=bold&text_u_style=normal&text_u_variant=normal&text_u_decoration=none&text_u_color_h=525284&text_u_weight_h=bold&text_u_style_h=normal&text_u_variant_h=normal&text_u_decoration_h=none";
ts3v_display.init(ts3v_url_1, 1057264, 100);
</script>
i tried using the builtin custom block/module function from the ACP and copy&pasted the javascript into the content part with the same result - it does not work.
Any idea how this should be done? Thanks for any help![/i]
Harledir
Re: own custom block with javascript
Post by Harledir »
i have no idea why, but this morning the blocks are showing the excuted javascript.
(i did delete cache etc...) oh well, at least it works. Please close this as resolved.
Harledir
Post by Harledir »
just noticed what happened, but don´t have a solution.
when viewing the site with HTTP everything works (javascript in the blocks is being executed)
when viewing it with HTTPS the blocks stay empty (javascript is not being executed / or the results are not being displayed)
How can i get this to work with HTTPS as well?
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
in your code try changing
http://
to
https://
and see if it still loads on your site with using HTTP:// and if it does then try it on HTTPS://
if its works on http but not https then theres not much you can does as its the source that is at fault for which you have no control of (Teamviewer will proberly have this problem)
