Redirect to Portal not Index after Login
ohockey
Post by ohockey »
Your Portal Version: 2.1.0-RC1
Boardlink: http://hockeytime.cu.cc
Nothing
Tried modifying ucp.php but it did not work
After login I would like users redirected to the portal page not the index page. Ideally, I would like the same after they logout as well.
ohockey
Re: Redirect to Portal not Index after Login
Post by ohockey »
I want to have the portal the default after login and logout. I currently use a redirect so users see the portal after going to my website. I tried modifying as suggested, even though my portal.php file is different. I get the error:
No route found for "GET /portal.php"
Can you tell me what is wrong?
My original file looks like the following:
// Basic "global" modes
switch ($mode)
	case 'activate':
		$module->load('ucp', 'activate');
		$module->display($user->lang['UCP_ACTIVATE']);
		redirect(append_sid("{$phpbb_root_path}index.$phpEx"));
	break;
	case 'resend_act':
		$module->load('ucp', 'resend');
		$module->display($user->lang['UCP_RESEND']);
	break;
	case 'sendpassword':
		$module->load('ucp', 'remind');
		$module->display($user->lang['UCP_REMIND']);
	break;
	case 'register':
		if ($user->data['is_registered'] || isset($_REQUEST['not_agreed']))
		$module->load('ucp', 'register');
		$module->display($user->lang['REGISTER']);
	break;
	case 'confirm':
		$module->load('ucp', 'confirm');
	break;
	case 'login':
		login_box(request_var('redirect', "index.$phpEx"));
	break;
	case 'login_link':
		$module->load('ucp', 'login_link');
		$module->display($user->lang['UCP_LOGIN_LINK']);
	break;
	case 'logout':
		if ($user->data['user_id'] != ANONYMOUS && $request->is_set('sid') && $request->variable('sid', '') === $user->session_id)
			$user->session_kill();
		else if ($user->data['user_id'] != ANONYMOUS)
			meta_refresh(3, append_sid("{$phpbb_root_path}index.$phpEx"));
			$message = $user->lang['LOGOUT_FAILED'] . '<br /><br />' . sprintf($user->lang['RETURN_INDEX'], '<a href="' . append_sid("{$phpbb_root_path}index.$phpEx") . '">', '</a> ');
			trigger_error($message);
	break;
	case 'terms':
	case 'privacy':
		$message = ($mode == 'terms') ? 'TERMS_OF_USE_CONTENT' : 'PRIVACY_POLICY';
		$title = ($mode == 'terms') ? 'TERMS_USE' : 'PRIVACY';
		if (empty($user->lang[$message]))
			login_box();
			'body'		=> 'ucp_agreement.html')
		// Disable online list
		page_header($user->lang[$title]);
		$template->assign_vars(array(
			'S_AGREEMENT'			=> true,
			'AGREEMENT_TITLE'		=> $user->lang[$title],
			'AGREEMENT_TEXT'		=> sprintf($user->lang[$message], $config['sitename'], generate_board_url()),
			'U_BACK'				=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=login'),
			'L_BACK'				=> $user->lang['BACK_TO_LOGIN'],
		page_footer();
	break;
My changed version is this:
switch ($mode)
	case 'activate':
		redirect(append_sid("{$phpbb_root_path}portal.$phpEx"));
	break;
	case 'resend_act':
	break;
	break;
	case 'register':
	break;
	case 'confirm':
	break;
	case 'login':
		login_box(request_var('redirect', "portal.$phpEx"));
	break;
	case 'login_link':
	break;
	case 'logout':
			meta_refresh(3, append_sid("{$phpbb_root_path}portal.$phpEx"));
	break;
	case 'terms':
	case 'privacy':
			login_box();
		page_footer();
	break;
Open: root/ucp.php
Find:
	case 'login':
	break;
Replace with:
	case 'login':
			redirect(append_sid("{$phpbb_root_path}app.$phpEx/portal"));
		login_box(request_var('redirect', "app.$phpEx/portal"));
	break;
Find:
	case 'logout':
	break;
Inline find:
Replace with:
ohockey
Post by ohockey »
Thank you for the quick reply. Before I get started, the 2nd find you listed does not have the equivalent replace statement that I believe should be listed. Could you please provide or explain if I am incorrect.
Sorry i can not translate this message.
The changes are all in the root/ucp.php.
thirdoff
phpBB.de User: thirdoff
phpBB.com User: thirdoff
Post by thirdoff »
How to redirect to portal all the time, even when not logged in?
