Missing steps for installation
Current Version: 2.0.2
Released: 2013-10-27
grazia
Post by grazia »
Your Portal Version: 2.0.2
I installed phpbb3 version 3.0.12 , after I scar4icato the board3 Portal 2.0.2 , but missing some step of the xml file , as I solve ?
Open: includes/session.php Find Tip:
 This may be a partial find and not the whole line.
:Select all if (!empty($_GET['style']) && $auth->acl_get('a_styles') && !defined('ADMIN_START')) Replace with Tip:
Replace the preceding line(s) to find with the following lines.
 if (!empty($_GET['style']) && !defined('ADMIN_START') && !$this->data['is_bot'])
in phpbb3 3.0.12 no file includes/session.php
Help me please
please help me , I could not have a stable installation[/i]
Re: Missing steps for installation
grazia wrote:in phpbb3 3.0.12 no file includes/session.php
The session.php is in the folder includes
grazia
Post by grazia »
ok, thank you for answer, phpbb update 3.1.2 version Ascraeus
Do you have 3.0.x or 3.1.x ?
For phpBB 3.1.2 take this version viewtopic.php?f=40&t=10857
Installing Extensions
For phpBB 3.0.x take this version viewtopic.php?f=40&t=10628
