Your Portal Version: 2.1.0-b1
Boardlink: http://www.noviciumguild.com/testoforums
PHP Version: 3.1.1
I installed portal into ext/board3/portal then used the customize tab in the PHPBB ACP to enable to extension.
I have been poking around for hours. I can not figure out how to edit portal in the ACP.
I would very much like to use a portal for my phpbb forums.
However, after i installed the extension i CAN NOT find where to edit the mod!!!
There is no tab in my ACP, and nothing in the extension tab for portal.
I have a screen shot but can not post it to these forums.
missing ACP portal tab
scotwray
- phpBB.de User: scottwray
- phpBB.com User: scottwray
Re: missing ACP portal tab
If the extension was properly enabled, it will show up once you click on the extensions tab in the ACP.
