Change font size in a single block
Current Version: 2.0.2
Released: 2013-10-27
cwjs
phpBB.de User: cwjs
phpBB.com User: cwjs
Post by cwjs »
Your Portal Version: 2.0.2
Sorry the question may be obvious to some but, I would like to increase the size of the font in the recent block only, could someone explain how
Thanks
Clive
Re: Change font size in a single block
Open: root/styles/stylename/template/portal/modules/yourblock
Find:
{$TITLE}
Replace with:
<span style="font-size:2em">{$TITLE}</span>
Change at 2em to your specifications.
cwjs
phpBB.de User: cwjs
Post by cwjs »
Hi Kirk,
Thanks for helping, but it only changes the title of the block, I want it to change what is inside the block (recent topics etc)
Regards
Clive
Open this Block
Find:
				<!-- IF .latest_announcements --><td class="row1"><strong>{L_PORTAL_RECENT_ANN}</strong></td><!-- ENDIF -->
				<!-- IF .latest_hot_topics --><td class="row1"><strong>{L_PORTAL_RECENT_HOT_TOPIC}</strong></td><!-- ENDIF -->
				<!-- IF .latest_topics --><td class="row1"><strong>{L_PORTAL_RECENT_TOPIC}</strong></td><!-- ENDIF -->
Add before:
Tip: Tip: Add these lines on a new blank line before the preceding line(s) to find.
Add after:
			</span>
Find 3x :
<span class="gensmall">
Replace with 3x :
<span class="gensmall" style="font-size:2em">
cwjs
phpBB.de User: cwjs
Post by cwjs »
Hi Kirk,
Brilliant !!, thanks for your help.
Regards
Clive
