Cynthia (Base: prosilver)
Style: Cynthia
Style Version: 1.0.1
phpBB Version: 3.0.12
Board3Portal Version: 2.0.2
Style Download: https://www.phpbb.com/customise/db/styl ... a/demo/3.0
to: root/styles/Cynthia/template/portal/*.*
to: root/styles/Cynthia/theme/portal.css
to: root/styles/Cynthia/theme/images/portal/*.*
open: root/styles/Cynthia/template/overall_footer.html
<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a><!-- ENDIF -->
open: root/styles/Cynthia/template/overall_header.html
<li><a href="{U_INDEX}">{L_INDEX}</a></li>
<li><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a><!-- ENDIF --><a href="{U_INDEX}">{L_INDEX}</a></li>
<div class="menu-user">
<em class="icon-home"></em> <a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks -->
<em class="icon-home"></em> <!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks -->
<div id="wrap">
open: root/styles/Cynthia/theme/stylesheet.css
@import url("cynthia.css");
Als erstes musst du den Style downloaden und Installieren. Wenn das geschafft ist und der Style läuft, kannst du das Portal für diesen Style nach folgender Anleitung installieren:
nach: root/styles/Cynthia/template/portal/*.*
nach: root/styles/Cynthia/theme/portal.css
nach: root/styles/Cynthia/theme/images/portal/*.*
Öffne: root/styles/Cynthia/template/overall_footer.html
<!-- IF U_PORTAL --><a href="{U_PORTAL}"><span>{L_PORTAL}</span></a><!-- ENDIF -->
Öffne: root/styles/Cynthia/template/overall_header.html
<div id="wrap">
Öffne: root/styles/Cynthia/theme/stylesheet.css
