Dualcore (Base: prosilver)
Style: Dualcore
Style Version: 1.0.1
phpBB Version: 3.0.12
Board3Portal Version: 2.0.2
Style Download: https://www.phpbb.com/customise/db/style/dualcore
to: root/styles/dualcore/template/portal/*.*
to: root/styles/dualcore/theme/portal.css
to: root/styles/dualcore/theme/images/portal/*.*
open: root/styles/dualcore/template/overall_footer.html
<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a><!-- ENDIF -->
open: root/styles/dualcore/template/overall_header.html
<div class="topnav">
<div id="wrap" style="width: {$BOARD_WIDTH};">
	<div class="mainheader">
		<div class="mainnav<!-- IF $MENU_ANIMATION == 'on' --> mainnav-animation<!-- ENDIF -->"><ul>
<img src="{T_THEME_PATH}/images/icon_home.png" width="16" height="16" alt="" /><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks -->
open: root/styles/dualcore/theme/stylesheet.css
@import url("dualcore.css");
Als erstes musst du den Style downloaden und Installieren. Wenn das geschafft ist und der Style läuft, kannst du das Portal für diesen Style nach folgender Anleitung installieren:
nach: root/styles/dualcore/template/portal/*.*
nach: root/styles/dualcore/theme/portal.css
nach: root/styles/dualcore/theme/images/portal/*.*
Öffne: root/styles/dualcore/template/overall_footer.html
<!-- IF U_PORTAL --><a href="{U_PORTAL}"><span>{L_PORTAL}</span></a><!-- ENDIF -->
Öffne: root/styles/dualcore/template/overall_header.html
Öffne: root/styles/dualcore/theme/stylesheet.css
