Add Twitter Full Length Middle Block
Current Version: 2.0.2
Released: 2013-10-27
Vampire77
Post by Vampire77 »
Your Portal Version: 2.0.2
Boardlink: http://www.homelessaustralia.com
Searched Forums, but nothing specific to this.
I have created a Widget in Twitter to add to the middle block. However it does not go full length. And is too high in height.
The code I was given by twitter is:
<a class="twitter-timeline" href="https://twitter.com/HomelessOz" data-widget-id="517030282558312448">Tweets by @HomelessOz</a>
<script>!function(d,s,id){var js,fjs=d.getElementsByTagName(s)[0],p=/^http:/.test(d.location)?'http':'https';if(!d.getElementById(id)){js=d.createElement(s);js.id=id;js.src=p+"://platform.twitter.com/widgets.js";fjs.parentNode.insertBefore(js,fjs);}}(document,"script","twitter-wjs");</script>
Thanks for any help with this.
Re: Add Twitter Full Length Middle Block
I have installed your widget for Twitter, can not find any fault.
Vampire77
Post by Vampire77 »
I have it viewing as the same, but isn't there a way to make it show over the inter middle part instead of just to the left.
The width is set by Twitter and can not be changed.
kradsith
phpBB.com User: kradsith
Post by kradsith »
To change the size add a style in front of your code in your custom block.
<style> .twitter-timeline { width: 150px; height: 300px; }</style><a class="twitter-timeline"...
