Php errors in recent block
Current Version: 2.0.2
Released: 2013-10-27
Nor7on
phpBB.com User: Nor7on
Post by Nor7on »
Your Portal Version: 2.0.2
I get this message in debug mode.
[phpBB Debug] PHP Notice: in file [ROOT]/portal/modules/portal_recent.php on line 70: Undefined index: board3_exclude_forums_11
In line 70:
			$sql_where = ' AND ' . $db->sql_in_set('forum_id', array_map('intval', $exclude_forums), ($config['board3_exclude_forums_' . $module_id]) ? true : false);
How i can fix it?[/i]
Re: Php errors in recent block
Open the root/portal/moduels/portal_recent.php
Find:
Replace with:
board3_recent_exclude_forums
Nor7on
Post by Nor7on »
Hi!
I found this:
So i have change to
$sql_where = ' AND ' . $db->sql_in_set('forum_id', array_map('intval', $exclude_forums), ($config['board3_recent_exclude_forums_' . $module_id]) ? true : false);
or
$sql_where = ' AND ' . $db->sql_in_set('forum_id', array_map('intval', $exclude_forums), ($config['board3_recent_exclude_forums' . $module_id]) ? true : false);
Thanks :oops:
Nor7on
Post by Nor7on »
KirK can you help me? :?
Replace with:
