Your Portal Version: 2.0.2
Boardlink: http://www.nocsclan.it
PHP Version: 5.3.28
MySQL Version: MySQL 5.1.73-1.1+squeeze+build0+1-log
Hi all, I installed the style "SE Gamer Dark", in the columns of the left and right I have left the background white and I do not no icon appears on the modules in the top left corner. ... How do I solve this problem?
Thanks
SE Gamer Dark problems
- phpBB.de User: Kirk
Re: SE Gamer Dark problems
I read that post but I found no answer to this ... someone can helpme!!
ok try now!Kirk wrote:Control the installation. Unlock the portal for guests free.
Copy: root/styles/prosilver/theme/images/portal/*.*
To: styles/SE_Gamer_Dark/theme/images/portal/*.*
ok! now i've fixed the problem of the icons above modules, but what about the color within the module, does anyone know how I can change it, is always whiteKirk wrote:Copy: root/styles/prosilver/theme/images/portal/*.*
open: root/styles/SE Gamer Dark/theme/colours.cssBixio wrote:but what about the color within the module, does anyone know how I can change it, is always white
Find:
ul.forums {
background-color: #262626;
ul.forums {
I had already read it and tried it but unfortunately it does not work
- phpBB.com User: Nor7on
I had the same problem, just i do refresh template, theme (of se gamer dark) and delete all files in "cache" folder, except index.html and .htaccess.
if it dont work, clear your cache of your browser.
I uninstalled the style .... I deleted all the files inside the folder "cache" except the 2 you said to me ...... I reinstalled the style .... and NOT CHANGED ANYTHING ... . did not know anymore what to doNor7on wrote:I had the same problem, just i do refresh template, theme (of se gamer dark) and delete all files in "cache" folder, except index.html and .htaccess.
You do not need to uninstall your style.
Changes to the themes:
Go to your ACP, choose "Styles -> Themes -> your style", which has been changed and click "refresh" - confirm with "yes".
Changes to forums styles
I deleted all styles (except of course Prosilver and Subsilver) I installed another style (ca-black) and did not work either, then I reinstalled again SE_Gamer_Dark ... and guess what ... it seems to work !!!!!!Kirk wrote:You do not need to uninstall your style.
Thank you very much for your patience and help !!!!
