Welcome Module Help
Current Version: 2.0.2
Released: 2013-10-27
Vampire77
Welcome Module Help
Post by Vampire77 »
Your Portal Version: 2.0.2
Boardlink: http://www.homelessaustralia.com
Installed the Forum and Portal. Done the edits and confirmed everything was correct.
Looked around and searched the Forum for the same problem. One other I saw had the same issue but was for another version and the coding appears to be different.
The color background of the welcome message is all blue and not grey like the other modules. I would like to have this part as grey also please.
Thank you.
Re: Welcome Module Help
Changes to the templates:
Go to your ACP, choose "Styles -> Templates -> your style", which has been changed and click "refresh" - confirm with "yes".
Changes to the themes:
Go to your ACP, choose "Styles -> Themes -> your style", which has been changed and click "refresh" - confirm with "yes".
In the end "ACP -> General" --> purge cache
Now all your changes should appear properly on your site.
Vampire77
Post by Vampire77 »
Thank you Kirk, that fixed my issue. :)
