[OBSOLETE] Cooliris-Youtube Block V1.0.0 [OBSOLETE]
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
THIS ADDON NO LONGER WORKS DUE TO YOUTUBE API CHANGES
Addon: Cooliris-Youtube Module
Addon Version: 1.0.0
Addon Author: Talonos
Addon Description:
this is a cooliris block that can be added ANYWHERE on your portal as block dimensions can be changed to suit your theme.
you can use 1 of 2 main option. display a certain playlist OR a youtube users uploads
total rows: select how many rows you videos you would like to display. example: 2 rows for a wide block OR 4 rows for a side block
Background image: change the overall background image displayed within the blokc (image shows best when block is displayed @ fullscreen player)
Background Color: change the background color if you don't use an image background
Height: change the height of the block to suit your theme
Width: change the width of the block to suit your theme
Glow Color: change the color of the outer edge of the video player
share button: enable/disable the built in share buttons (Facebook/Twitter)
Search: Enable/disable the option to search the video's displayed within the block ( uses the glow color for the non matching results)
Tutorial: Enable/Disable a basic tutorial displayed to users
Background images must be stored in
{T_THEME_PATH}/images/portal/cooliris_youtube/
Addon Requirements: Board3 Portal 2.0.0b1 and newer.
Download Link is here:
http://pretereo-stormrage.co.uk/viewtopic.php?f=12&t=29
Instructions:
2. Add new module into ANY column of the portal (ACP > MODS > Portal > Portal Modules).
REVISION INFOMATION
1.0.0
Initial Release
SCREENSHOTS:
