ok so i've started work on a new block. Cooliris Youtube block
i have a demo running on my site currently and am looking for some feed back on it upto now.
options within the ACP will range from:
setting size of the block (block can be used ANYWHERE on your portal).
displaying a Playlist OR User uploads
options to change some visuals (show hide share/search buttons AND background color)
option to have background color OR image
select how many rows of video thumbnails to show (1-6)
DEMO: http://pretereo-stormrage.co.uk the demo is at the bottom of the page.
tell me your thoughts about the block and any possible ideas you may have to improve it in future.
sidenote: i know cooliris can use other platforms and even rss feeds and if i do them platforms in future they will be seperate from this one so you could run multiple cooliris blocks on your portal if that is a desire.
[DEMO] Cooliris Youtube Block
Topic author - Portal Specialist
- phpBB.com User: talonos
Re: [DEMO] Cooliris Youtube Block
now released @ http://board3.de/viewtopic.php?f=54&t=10803
