DirtyBoard2.0
Cforcer
phpBB.com User: Cforcer
DirtyBoard2.0
Post by Cforcer »
Your Portal Version: 2.0.2
Boardlink: http://www.slovaper.eu/portal.php
PHP Version: 3.0.12
MySQL Version: 5.5.37
Installed the portal...
Have no idea how to fix those...
I've installed latest portal version on my phpbb board... Everything looks fine even middle module columns looks nice... Have problem with both left and right modules... Everything is little too high for my DirtyBoard2.0 theme... as you can see from my screenshot....
http://prntscr.com/430616
Please help me fix this... I've temporary disabled this theme on my board since it looks weird, but I'd like to use it if it's possible...
Any help appreciated... :)
Re: DirtyBoard2.0
The styles is based on old phpBB version 3.0.11.
We write only tutorials for the styles based on current phpBB version!
You can try these instructions if they are able to adapt to the current portal and to the latest phpBB version.
viewtopic.php?f=47&t=3875
viewtopic.php?f=44&t=3862
We give no support for these old instructions, because these were written not for current portal and not for current phpBB version!
Cforcer
Re: DirtyBoard2.0
Post by Cforcer »
Thank you very much. Have found the solution, just change "margin-top: 22px;" in current "DirtyBoard/template/portal/_block_config.html" file (config for left and right blocks) and theme looks perfect on latest Portal... :D
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 00px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 22px;">' -->
Return to “Styles Support”
