Install phpbb and wow cataclismo style
Read the install xml on the folder
Hello,
Someone knows how to fix this problem please? :
http://img11.hostingpics.net/pics/874339Sanstitre.png
I wanted to install a portal on my forum phpbb ( with Wowcataclismo style) but as you can see , the portal isn't clean.
I saw a forum similar to my forum whose portail is very clean and well made / installed.
http://die-freaks.com/
Sorry for my bad english , i'm not english x)
Thanks.
Template wow cataclismo
Re: Template wow cataclismo
But there are a difference between my site and http://die-freaks.com/ x)
i think he's on about the "fixed width" i used to use the same theme and removed it due to that issue. on very high resolution screens it didn't resize to fit.
