Artodia: Deluxe (Base: prosilver)
Style: Artodia: Deluxe
Style Version: 2.0.3
phpBB Version: 3.0.12
Board3Portal Version: 2.0.2
Style Download: http://www.artodia.com/phpbb-styles/deluxe/
to: root/styles/art_deluxe/template/portal/*.*
to: root/styles/art_deluxe/theme/portal.css
to: root/styles/art_deluxe/theme/images/portal/*.*
open: root/styles/art_deluxe/template/overall_footer.html
<a href="{U_INDEX}" accesskey="h"><span>{L_INDEX}</span></a>
<!-- IF U_PORTAL --><a href="{U_PORTAL}"><span>{L_PORTAL}</span></a><!-- ENDIF -->
open: root/styles/art_deluxe/template/overall_header.html
<div id="menu-wrapper">
    <!-- IF S_USER_LOGGED_IN and S_DISPLAY_PM and S_USER_NEW_PRIVMSG -->
    <div id="newpm" class="rules">
        <div class="inner">
            <a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>
open: root/styles/art_deluxe/theme/stylesheet.css
@import url("layout_responsive.css");
Als erstes musst du den Style downloaden und Installieren. Wenn das geschafft ist und der Style läuft, kannst du das Portal für diesen Style nach folgender Anleitung installieren:
nach: root/styles/art_deluxe/template/portal/*.*
nach: root/styles/art_deluxe/theme/portal.css
nach: root/styles/art_deluxe/theme/images/portal/*.*
Öffne: root/styles/art_deluxe/template/overall_footer.html
Öffne: root/styles/art_deluxe/template/overall_header.html
        <div class="inner">
Öffne: root/styles/art_deluxe/theme/stylesheet.css
