Photbucket Slide Show in Custom Block
Current Version: 2.0.2
Released: 2013-10-27
AussieD
Post by AussieD »
Your Portal Version: 2.0.1
Boardlink: http://aussiedistiller.com.au
Nothing, there is no Problem :)
Im looking to create a photobucket slideshow and place the slideshow into a custom block. Something similar to whats seen here: http://www.aquafora.nl/portal.php down the left side would be fantastic.
I have tried all the codes that photobucket give me but nothing works.
Is this possible ?
Am I better off getting some sort of gallery module (if ones available) ?
Any advice would be greatly appreciated
Re: Photbucket Slide Show in Custom Block
There are lots of web scripts for a slideshow.
example:
http://www.bretteleben.de/lang-en/javas ... eshow.html
AussieD
Post by AussieD »
Thanks but not much help to me as I dont understand what I am to do with that.
