Addon Version: 1.0
Addon Author: Aleyah
Addon Description:
This is a guild recruitment display module based on Talonos WoW Module. Specs are displayed on the portal via images and transparency for images is set in the ACP base on a a Priority level (none-low-medium-high). You can set the block to only display classes that you are recruiting OR display all classes. Class images can be enabled/disabled. Clicking on a spec image will direct you to the forum/link of your choosing for said clicker to make an application to the guild be it from an application form or a forum which is custonisable from the ACP aswell
Addon Requirements: Board3 Portal 2.0.0b1 and newer.
Download Link : https://mega.co.nz/#!hlhBEIhT!gEJxjeEv3 ... ev9UHr-qQU (temporary, full website with demo and domain name is coming)
Git Repository : https://github.com/Kyah/board3_wildstar_recruitement
Demo : http://demo.octetsetquartdepouces.net/phpBB3/portal.php
Instructions:
2. Add new module into left or right column of the portal (ACP > MODS > Portal > Portal Modules).
REVISION INFOMATION
1.0.0
Initial ReleaseModule includes french and english version, feel free to add new languages and post it here or make a pull request in the git repository
